Stupid Question Alert
strocky
1,879
23
Lanarkshire
Need a mono Phono cable to connect the centre Pre-out of my AV Amp to the centre channel of my power amp,
Is it ok to use a Profilgold 75 Ohm "digital" Coax cable to carry the analogue signal?
strocky
1,879
23
Lanarkshire
Cheers, one further probably stupider question is it ok to use an 2 additional pairs of 75 Ohm analogue (fronts) AND 2 additional standard RCA cables you get with a Squeezebox touch for example (rears)
No Ohms marked on the standard cheapy cables
V
Voice_Coil
Cheers, one further probably stupider question is it ok to use an 2 additional pairs of 75 Ohm analogue (fronts) AND 2 additional standard RCA cables you get with a Squeezebox touch for example (rears)No Ohms marked on the standard cheapy cables
plug them in and stop stressing.
strocky
1,879
23
Lanarkshire
old_school
389
3
Jay
75 Ohm cables are fine for analogue connections. The other way 'round (bog-standard analogue cables in digital connections) can be a problem.
SergeAuckland
Certified Measurist
18,607
1,915
Bury St Edmunds, UK
Serge
And even then, unlikely with the sort of short lengths common in a home system.
S
