Suggestions on treating rust spots before painting
graham67
3,776
1,048
I have some thick steel speaker stands that have some small chips to the paint. The steel under the missing paint has oxidised and is rusty.
Can anyone please suggest how best to treat the rust spots so that i can then paint the chips with enamel paint? As the chips are small, it is likely that the treatment will spillover to the painted sections,so I need something that can be applied accurately or will not cause significant damage to the painted bits.
Many thanks,
Graham,
SMEagol
Middle Earthed
7,556
464
163
Lancashire
