G
Sometimes the answers are not where you think . If i follow my thought processes back i would never find theone possiblesolution to the bain of hifi owners . The suspended wooden floor.:Upset:
A speakers potential can and is seriously hampered by the energy travelling through your speaker into the floorboards and consequently you phoning the local seismology centre to report underground subsonic activity in Sidcup. Apparrently the last earthquake in Sidcup was at the moment of Big Bang but as no records were kept then they can't with any great authority say that was the case.:Not Sure:
Anyway one possible answer to this problem comes from the pro world of Music and a big thanks to Mosfet for this one. Its with no suprise that most concerts are played on stages and obviously some stages are bouncier than others. So what do those sneaky musicians use to combat that bass chord reaching the audience rather than Australia.
Well its one of these
The company is called Auralex and they make acoustic foam . Yes this platform which is only 23 inches by 15 supports 300lb's. Yes thats right one Hifiwigwam per support and all for the ground breaking price of £55-60 per platform. Now underneath are two wedges which run the full length of the support and in the middle is some acoustically treated foam that you would normally see on the walls of a recording studio.
Now energy transmitted and then bounced back cancause congestion and poor bass response . The mids and trebles can sound closed in and your cup of tea can also fall off the table
Is this a cure for all. No but its much more of a cheaper option than totally decoupling the speaker like Airtek or Townsend. Stability seriously isnt an issue as some might think. I will be next placing some marble plinths on top which again is a much more cheaper option to tighten the bass up further. This is all part of a fine tuning operation . I 've lived with these platforms for a week and though they are pig ugly they can be easily disguised and will be once i've settled on the final set up.
:dude:
:dude:
