Linn Owners
Switch between Exaktbox-I and AV5125
aurelio
86
153
53
Hello,
before the prise raise I pulled the trigger on an Akurat Exaktbox-I to run my Espek/5140s exakt.
I was running the Espek/5140s aktive before with two dynamik AV5125s.
With the Exaktbox, I changed from the BFA connectors to banana connectors.
Now that I am familiar with the sound of the Exaktbox-I, I would like to do a comparison between the Exaktbox and AV5125 amplification, using the analogue outputs of the Exaktbox into the AV5125s.
Changing back and forth between the Linn BFA and the banana connectors is quite a hassle.
Are there any decent connector options that I can use with both amps?
From what I figured out, 4mm hollow banana plugs should do the job, but i don't know if the extra plastic isolation on the BFA connectors is a must.
I am using K400 as speaker cables.
And is the effort worth it at all, or should I just stick with the Exaktbox-I amplification and just forget about the itching that makes me want to compare?
Any suggestions / feedback appreciated.
Reactions: Paulssurround
Jail4CEOs2
1,862
1,159
Taiwan
LG G2 65 OLED
I have done that same comparison using my MEB-i alone or into a 6100D. Yes you should absolutely do it!
HectorStolz
