Hi Guys,
I've not posted here in ages, so I thought I'd just give you a small update.
The Marco boy no longer uses Naim gear
Yep, it's all sold, gone, adios amigos...
What's the numpty using now, I hear you ask?
Well, it's a wee bit different fae before!
SOURCE 1
LP12 (with Funk Firm Achromat)/Hadcock GH242 Integra/Koetsu Black with Graham Slee Elevator EXP step-up transformer& Norton Airpower PSU.
SOURCE 2
Micromega Duo transport & BS2 DAC.
SOURCE 3
Quad FM4 tuner.
AMPLIFICATION (PREAMP)
Croft Charisma 'X-spec' valve preampwith (all-valve)MM phono stage.
AMPLIFICATION (POWER AMP)
ECS EA-1 200W monoblocks.
LOUDSPEAKERS
Spendor SP100 in Rosewood finish.
WANKY WIRES (MAINS LEADS)
Transparent Power Link Plus/MusicWorks+/MusicWorks STD
WANKY WIRES (INTERCONNECTS & SPEAKER CABLE)
Transparent Musiclink Plus/Van Den Hul The First Ultimate/Stereovox HDXV/Chord Silver Siren/Transparent Music Wave Plus.
EQUIPMENT SUPPORTS - yes, the Mana is still there
LP12 on Phase 14 (13x Soundstages & 1x Reference Top).
Micromega transport & DAC on stainless steel 6-tier rack with Reference Top @ Phase 10 (Ref Top, rack, and 8xSoundstages).
All other gear on stainless steel 6-tier rack @ Phase 9.
Spendor SP100 on Phase 6 (custom-made stands & 5xSoundbases per side).
'MAD BASTARD' Mains set-up
Dedicated separate spurusing 32mmarmoured cable, Memera 6-wayCU with 'uprated' bussbar and 63A MCBS. Allequipment hard-wired directlyinto CU using Furutech Rhodium-plated spade connectorswithmains leads as specified. Dedicated separate star-wired commonEarth for system via 5x 8ft copper Earth rods with16mm audiophile grade Earth wire, feeding back to the CU.
And it sounds 'no bad'
Reet-o, I'm off to listen to some more choons...
Laters,
Marco.
SOURCE 1
SOURCE 2
SOURCE 3
Quad FM4 tuner.
LOUDSPEAKERS
Laters,
Marco.
