Hi Folks,
Just finished a solid walnut plinth for my mates Thorens deck, thought I would share the results.
This was machined from a single length of solid walnut, mitres cut on a Morso guillotine and jointed with a Festool domino joiner. I was then sanded back smooth through several grades of sandpaper and two coats of hardwax oil was applied followed by 3 coats of wax and then hand polished.
some rubber feet have been fitted to the corner bracing to lift the turntable by 2mm from whatever it sits upon.
DSCN1800 by simon ms, on Flickr
DSCN1804 by simon ms, on Flickr
DSCN1802 by simon ms, on Flickr
DSCN1805 by simon ms, on Flickr
Cheers Si.
Cheers Si.
