Hi all,
In a day of firsts, this is my first post regarding the first turntable I've owned since the plastic one that I played with as a child.
I recently picked up a Thorens TD160 in really quite good condition but it still has the original power cable, DIN connector, etc. Basically, it looks as though it has sat on a shelf for 40 years and has been lovingly cared for and sporadically used.
I've had a scan through www.theanalogdept.com and read about the various modifications that can be done, however, I'd like to hear some opinions from you all about what I could/should do to start with. ie. should I replace the bottom plate? If so, what with? MDF? Plywood? I'm not afraid of a little DIY and pulling the turntable apart doesn't intimidate me (too much) but I don't have much of a workshop in my tiny London flat so I have to be realistic how much I can do.
Also, if anyone has any spares or bits and pieces kicking around in the bottom of a drawer that you think I could use then I'd happily take them off of your hands.
After all of that I can start thinking about a phono stage or an old amp with a couple of bookshelf speakers...
Thanks a lot.
Cheers,
Scott
Thanks a lot.
Cheers,
Scott
