Not sure whether it is appropriate to list in this forum but here goes.
I have been using this router for the last 2 years primarily to stream wirelessly from the modem located at the front of my house to my music system and other devices located at the rear. It has worked perfectly at all times but the provision last week of a new VM Hub 5 as part of a 1Gig fibre package has proved similarly capable of reaching the various devices located throughout my property and so there seems little point in keeping this one.
I have little technical knowledge of these things but lifted the following from the TP-LINK website:-
. Please see the attached photo.
I have just checked online and these are currently retailing at £149.99.
Asking £60 delivered in the UK. I will perform a factory reset before posting.
- The Fastest VDSL Modem Router – The Archer VR2800 runs at 2167Mbps on 5GHz and 600Mbps on 2.4GHz
- 1GHz dual-core CPU – Broadcom 1GHz dual-core CPU with two co-processors keeps VR2800 running at peak performance
- TP-Link Tether App – TP-Link Tether app helps you set up and manage your Archer VR2800 from any Android or iOS device.
