Transmission Line Speaker Build
slavedata
949
612
123
Bottesford Melton
Dave Slater
I have acquired some KEF B200's and T27 1231 tweeters plus some chunky looking KEF 2 way crossovers. I fancy having a go building some transmission line cabinets for these. Can anyone point me at some suitable cabinet designs on the web?
Thanks
Dave
DrBoar
21
HFN&RR had a design very similar to IMF 50 with a KEF B200 T27 and crossover. I would suggest damping the first half of the pipe to reduce the harmonics but keep the rest open to get the most of the fundamental ( the illustration below is more like the bigger IMF TLS 80 but the damping layout should be along the same lines
MF 1000
Extreme Full Range 😱
6,171
4,731
Caego
Keith
The best KEF driver to use in as transmission line is the B139 'race track', T27 tweeters are excellent for the top end - what were u planning to use for the mid range?
The classic trio is B139 bass, B110 mids & T27 tweeters. B110 drivers are now quite expensive but equivalents available from monacor ( and falcon audio were having some remanufactured I believe). This trio works well in both transmission line & ported designs too.
For a 'simple' TL design/build have a search for the plans for Cambridge R50 ....pm me if you get stuck as I have them on pdf
DrBoar
21
Slavedata, there were several versions of the B200 with various characteristics most notably Qes. They will work diffrently in a given TLS.
Here are the scanned article for one of the B200 versions. SP1014 probably benefit from full damping and SP1054 will need less damping ( or rahter more of radiation resistance at the fundamental) The SP 1022 SP 1039 and SP 1063 is in the middle and there it depends...
I would leave out any damping material in the two final sections and then have a sheet of BAF to slide into the final section to find out what damping works best. Put the crossover in the base of the speaker, as inside the speaker is a terrible place for crossovers due to the enourmous soundpressures inside the box. If you start using Speakon connectors you will never go back to those other binding posts.
I would not bother with the roofing felt but rather go for 4mm selfadhesive bitumen pads as sold in stores that sell car parts, car hifi and such.
