You shouldn't be in danger of frying owt I don't think......but too much gain or non optimal settings are likely to sound fairly odd IME. A mate of mine bought my old Project Tubebox S.E. phono stage to use with her newly aquired Rega P3 TT ready mounted with a Sumiko Blue Point Evo III H.O.M.C. cart. I got a panicked call the afternoon she hooked it up saying it wuz sounding 'echoey' & all wrong.
At the time I struggled to think wot could be the cause as I'd tested it before letting her have it & subsequently made sure I'd set the dip-switches right fer H.O.M.C. carts. I offered to go across the next day & check things out as Jen has been known ter do the odd wiring SNAFU, but swore blind she hadn't touched the dips....which wuz my first thought.
T.B.F. I never even considered the cause might be feeding the external stage into her integrated amps phono stage......Although that thought came to me in the early evening & on phoning her in the evening that wuz indeed wut she'd done.
I did have a nice big Yammy integrated years ago, long before I ever explored LOMC carts. This amp had a switchable MM/MC stage & inadvertently having it set to the MC gain setting for my Goldring 1042 MM cart certainly resulted in it sounding rather odd/not pleasant as there wuz simply way too much gain.......But no damage occurred. :nup: :^
Scratch that. Just read the sale thread where it came from.He was using a separate SUT, not a separate stage.
Sorry Rick.....I seem to be missing summat here.........don't see that an SUT would be advised for a Denon DL110 as its a HOMC & using a standard MM input + SUT with a HOMC.....the gain structure would be all wrong/way to high.
I think some stages that have a good range of adjustments allow you to adjust the loading more specifically for HOMC carts & fer LOMC's carts too come ter that. However the MC gain/step up stage generally isn't used as this would overload the input as it'd be way too high. Many switchable stages don't offer this though & convention is that in this case you simply use the MM setting for a HOMC.
