Suitable for the design it’s fitted to! That’s all.What exactly must the perfect platter be?
I had several mats for my Linn but the best was the achromat by funk firm ..cork can be a good alternative and much cheaperI have an LP12 with a black felt mat. I have a suspicion that the mat encourages static. Am I right, and is there an alternative mat that doesn't have that disadvantage?
Changing the mat to another type will alter the sound of the lp12. IME The best way to remove static from records is to clean them with an ultrasonic RCM.I have an LP12 with a black felt mat. I have a suspicion that the mat encourages static. Am I right, and is there an alternative mat that doesn't have that disadvantage?
I have considered that as wellThe best way to remove static from records is to clean them with an ultrasonic RCM.
Resonance and mass/weight.
This👍 but applied to a Technics 1200G.I had several mats for my Linn but the best was the achromat by funk firm ..cork can be a good alternative and much cheaper
How would it change if I got the achromat (which other people seem to rate)?Changing the mat to another type will alter the sound of the lp12.
Hi Phil,How would it change if I got the achromat (which other people seem to rate)?
Doesn’t have to be an ultrasonic cleaner, I use a Pro-Ject vacuum RCM and no static.I have considered that as well
I have a suede leather mat. I love it.I have an LP12 with a black felt mat. I have a suspicion that the mat encourages static. Am I right, and is there an alternative mat that doesn't have that disadvantage?
Steady TigerI have a suede leather mat. I love it.
I think it gives me the benefits of both felt and cork without the static and well, it's black leather.Steady Tiger![]()
