Turntable wall shelf
rorackowe
69
Cheltenham
Roland
I'd like a shelf for isolation and to keep little 'un's mitts off my gyro. Any suggestions? Any suitable dust covers?
luckysim0n
1,874
574
Simon
Look in the review section there is a turntable wall shelf in there that is a work of art as well as getting a good review would match the aesthetics of the Gyro IMHO plenty of covers on the bay depends what you are looking for
Pussycat
1,716
25
78
Norwich
Mike
One of the most available s/h, from £30 to £50, is one of the Target shelves, of which there were about 3 models. All have spikes and should have lightweight, composite 'wooden' shelves. Avoid glass for Gyro and Orbe. A solid wall is advisable, too !
http://i719.photobucket.com/albums/ww195/Yungiloo/6.jpg
As regards covers, design your own and either have it made up locally at a perspex company or one of those online (which are, understandably, slightly dearer); should cost no more than £80 locally (for 5mm Perspex as I have, or less for 3mm, which is obviously not as rigid). Hope this helps.
rorackowe
69
Cheltenham
Roland
Local company for the cover's an excellent idea.
I used to have a target wall shelf for my Linn Basik, sold it 15 years ago :( looks like I'll have to find another or investigate the modern alternatives. Hoping not to spend an arm and a leg.
Pussycat
1,716
25
78
Norwich
Mike
When designing your own cover, bear in mind:.....extra height in case of upgrades to deck (you are restricted to width and depth by the shelf):......put hand-hold slots in the sides nearer the top than bottom;.........have a nearly full-width cut-out of 2 or 3 inches at the back:... you'll be offered choice of tints but bear in mind that the seams will show up as solid colour (as I found out !!!!!!!)
zlatan
