Linn Owners
Urika question
Ron.P
250
380
I find it annoying that Linn don't make their fully detailed manuals easily available.
Question I'm trying to answer is: how does one adjust cartridge loading? IMO there's no such thing as one perfect number.
ThomasOK
1,870
3,703
133
Westland, MI USA
Thomas O'Keefe
There is no adjustment available on the Urika 1. The settings are fixed where Linn felt they were best for Akiva, Kandid, etc. and work well with a range of cartridges. Adjustability was left out consciously in the effort to keep the signal path as simple and pure as possible. Switches in the signal path do degrade the sound, especially so at the extremely low voltage levels coming out of MC cartridges. This same engineering policy was followed with every Linn MC phono stage from that in the LK1, through the Kairn and the Linto to the Urika 1. Only the Uphorik and Urika 2 have switchable loading.
Ron.P
250
380
Thanks Thomas. Do you know what number they pick for resistive loading for the Kandid?
Moomintroll
3,043
3,718
From the doc I linked above -
75 Ω in parallel with 10 nF
’troll
Dasher
936
1,034
98
This is why I use a Uphorik. I've had many Linn Phono Stages - including Linto and the Kairn. I once bought a Klyde and was rather unimpressed - but then played it through a PS that allowed switching and was amazed at what out could do. I can see the benefits of the short signal path but as I don't use LInn cartridges I find the ability to match with switches outweighs the loss. The switches in the Uphorik can be made permanent once you find Nirvana (mine aren't)!
(Edited - I didn't spot that I was listening through Vietnamese Broth)!
StellanH
59
71
38
I have Klyde, it sounds just fine with a LK1 and should do so with all subsequent LInn preamps with fixed loading. I cannot see any benefit for variable loading in that case....
ketojenniel
