USB to SPDIF or Opti - CHEAP solution wanted
budgetblown
1,931
4
Cardiff, UK
Leigh
I know you get what you pay for - but I'm trying to do lots of stuff at the moment so funds are (as usual) tighter than a sharks bum at 40 fathoms. I need to go from USB to SPDIF or Opti so I can run into the back of a Thule PR350B and flog my upgraded Beresford 7520 DAC - the Thule sounds better anyway, so it makes sense. There's a few things catching my eye on a well-known auction website that shall not be mentioned...
please pardon the links, oh modlyrators - does anyone have any experience of any of these bits of kit, or some recommendations for cost-effective solutions?
http://www.ebay.co.uk/itm/USB-6-Channel-5-1-External-Audio-Sound-Card-S-PDIF-/170618507778?pt=UK_Computing_ComputerComponents_SoundCards&hash=item27b9a7d202
http://www.ebay.co.uk/itm/MUSE-HiFi-PCM2704-USB-to-S-PDIF-Converter-DAC-Sound-Card-Silver-/360598939209?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item53f55f2649
http://www.ebay.co.uk/itm/61961-DeLOCK-USB-Sound-SPDIF-Adapter-/400488117267?pt=UK_Computing_Other_Computing_Networking&hash=item5d3ef3b413
http://www.ebay.co.uk/itm/Hi-Fi-CM6631-USB-to-Coaxial-Optical-SPDIF-Convertor-For-DAC-192KHZ-24bit-ASIO-/281054804662?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item41702bfab6
Heck, I'd even be interested if anyone's got summat to flog cheap :p , or would consider taking the Beresford (which has had the op-amp upgraded and has an upgraded power supply) in PX, cash either way. Drop me a PM if so. Something cheaper is definitely the way I want to go since I've still got to pay for the Thule, but anything within reason considered.
meninblack
22,674
1,107
The Behringer UCA-202 is excellent. I also have an MF V-link (much more expensive) but I prefer the Behringer. It was also better than an M-Audio Transit.
brystonian
2,542
324
Bedfordshire
Jim
If your using a desktop rather than a laptop. Most of the motherboards have pin outs on the board for a SPDIF header. But you don't get the header in the box. I got mine for about a tenner. Might be worth a look?
http://www.ebay.co.uk/itm/Asus-SPDIF-Out-Coaxial-Out-Optical-Out-Module-/260708949431?pt=LH_DefaultDomain_0&hash=item3cb376ddb7
http://www.ebay.co.uk/itm/Gigabyte-Motherboard-S-PDIF-IN-Cable-header-connector-/230685774867?pt=AU_CablesConnectors&hash=item35b5f19413
Edit: Come to think of it, I've got a Gigabyte one sitting in a draw. So If you've got a Gigabyte board I'll stick it in the post.
SergeAuckland
Certified Measurist
18,607
1,915
Bury St Edmunds, UK
Serge
UCA 202 everytime. £20 from amazon! according to nuavguy it even measures well!
Indeed. I use the UCA202 as a DAC not just for USB-optical. I've installed a few at the radio statiokn for Presenters' laptops and they have been very reliable.
S
cjr
8,508
43
UK
UCA 202! so good I have 2 of them in my PC setups to provide SPDIF toslink to a stereo digital amp & an AV amp. Also great as a nice little headphone amp you can adjust with the volume headphone dial on the hoof. Also sounds pretty decent to me as a USB DAC in its own write and feeding an anlg amp. (I also had a M-Audio Transit and the UCA 202 is if not equal then superior to the M-Audio device). Superior in that the anlg input/outputs are RCA!
Buy a UCA 202/222 try not to go over £20 when doing so.
budgetblown
1,931
4
Cardiff, UK
Leigh
Thank you all for the input - Smegger68 has offered me a free adaptor he bought in from China, but if it proves inadequate then I'll upgrade to the Behringer.
craigmclellan
2,335
107
Boston, Lincolnshire
Craig
Sorry to hijack!
At the moment I have a HDMI cable running from my HTPC to the TV, then I have an optical cable run from the TV to my VA555ES. It does work fine, I even get AC3 passed over, but it doesn't allow for DTS and I get total cut out when scenes go quiet, which is distracting.
Is the UCA202 capable of doing "S/PDIF passthru" so I can get AC3/DTS on properly encoded movies?
Thanks in advance!
craigmclellan
2,335
107
Craig
It's set to "Audio System" so it is effectively S/PDIF passthru (Dolby Digital 3/2.1) is passed to the amplifier, but it does not send DTS, so need another device to achieve this.
My last PC had an S/PDIF output on the rear, irritatingly this machine does not. Does the Behringer do S/PDIF passthru? Or shall I find out by burgling your house? :D
meninblack
22,674
1,107
It doesn't - it is primarily designed as an interface to connect musical instruments to a PC for recording and mixing. Playback is just an afterthought.
