I have an Allo Digione that i bought second hand and use as the streamer for my main system . It came with a Raspberry Pi 3 unit attached but I had a spare Raspberry Pi 2Mb unit so decided to switch it over and use the newer and quicker Pi instead.
No mechanical issues just a straight swop . Then flashed a new card with Max2play but had repeated bricking of the unit (in reboot just stalls and stops working) . Not what I was looking for so downloaded Picoreplayer 6.0 flashed that to the SD card and set up Allo Digione as the player . No problems with that presume becuase they use a very small code package for the Raspberry Pi and not the full blown Buster . Works now so will leave it as it is . Would prefer to have it working under Max2play as all the others are doing but will have to see if I can find a resolution to loading that .
