using the output from tv has a delay through hifi amp even using digital input why !
Hornucopia
5,439
393
Bristol, , United Ki
It's just an annoying feature of Digital.! Try playing Digital Radio in one room and Analogue Radio in another....!! Big Echo!
You can get amps that will put a (variable) delay in to match, but...is it worth it?
just use the amp?
listener
49
Harrow
I have a TV upstairs that uses Freeview and one downstairs that runs on Freesat.There is a time delay ,echo like, between the two systems.Is there any possibility that both of these systems are present in your TV.Maybe one from a freeview tuner within the TV and another feed perhaps from a Freesat recorder connected to the TV.If so then the output you have connected to on the TV may be from a different source than the one driving the TV speaker.
Just a thought,if it's not that then I give up.
Pete.
V
Voice_Coil
Am i missing something but you can't use the tv volume and the amp volume or it sounds like an echo because of the delay:?
you dont have a centre speaker ?
mine does the same thing, but i dont see the point in having an av amp, only to use the tv speakers, its utterly pointless.
hifinutter
346
3
north yorkshire
you dont have a centre speaker ? mine does the same thing, but i dont see the point in having an av amp, only to use the tv speakers, its utterly pointless.
no i was trying to beef up the sound on a flat screen tv with an amp and some speakers nothing fancy really
Tel
30,426
657
Hove Actually
Kevin
I use a cheapish pair of active speakers and use the phono output from the TV.
If I want to use the full hifi system I use the optical digital output from the TV into the DAC.
No delay on either
G
If you're using the digital output from the TV and neither amp nor TV are doing any surround sound processing you should be OK. That's what I do (TV TOSLINK out into DAC then HI-FI) and there's no noticeable delay.
Is there a delay you can configure to compensate in the TV, perhaps?
Dungtran
