Thinking I could find something better suited to my new speakers. I've read the 20+ page tannoy thread and a lot of different amps being discussed but I didn't see one clear winner.
If I sell my amps and add a bit, budget would be probably 1200-1500 for something used. Integrated would do. I have no idea on all the different configurations but I want something of decent build, powerful enough, good reliability and isn't going to burn 3kw/h or whatever.
Any suggestions? I don't want to fart about chopping and changing, I just want something that'll be a worthwhile upgrade and will fit first time hopefully.
I listen to all types of music so it's got to be a good all rounder. I played some CDs earlier to a friend and while he said the acoustic stuff sounded excellent, some of the first Prodigy album sounded 'below average'. But then I don't know how well any valve amp would cope with dance music. To be honest it's sounding better than it ever has and we were being critical. I could quite happily live with it as is.
Half of me thinks ah fuck it just keep what you have a bit longer and get used to it with the new speakers instead of travelling the rocky road of frustration and uncertainty, but you never know. Perhaps I need an amp bake off. Now I've got a dedicated phono/sut I don't need to worry about relying on the 99pre anymore for my turntable - which was part of the initial plan
Cheers.
Cheers.
