Valve amp repairs
Idlewithnodrive
Class A, all the way
6,205
9,326
Virtually, everywhere
Mike
I know this has been asked before and I've done a quick forum search but can't find a relevant answer.
Evening all.
The output transformer on my Border Patrol 300B Power Amp seems to run ridiculously hot, as in you can't leave your finger on it for even a second (I know, why would I want to do that ? 🙂) and after about 30 minutes there is a whiff of rather warm (not cooked) electronics.
So, I'd like somebody knowledgeable to take a look at it for me. I'm based in Luton, Beds (J10, M1) and happy to travel an hour and a half'ish each way.
Any suggestions appreciated.
audio_PHIL_e
audioPHILe
11,291
163
The wrong planet
soundcloud.com
Phil
I'd guess (from a hot OPT and a red anode) that the o/p valve is passing way too much current which may in turn imply that its bias has gone awol. That is (afaik) less likely with cathode-bias, but could happen with grid-bias either via a severed connection from the bias supply to the grid, or because the bias supply has failed. I'd also suggest the symptoms are Not Good for the OPT or the o/p valve, and that you should find a substitute amplifier and/or get yours fixed asap.
Idlewithnodrive
6,205
9,326
Mike
The Amp has been stood down for the last couple of weeks, so no chance of any further damage being done.
.......... hence my post here 🙂
Reactions: audio_PHIL_e
andya
8
22
Swindon, Wiltshire,
Andy
Evening all.
Deco Audio in Aylesbury will repair and service valve amps. Sorted my Audio Research Classic 30 for me at a reasonable cost.
toprepairman
1,119
480
Surrey
Henry
Thanks John for the recommendation.
By sheer chance I'll be in Luton on Wednesday delivering the Mrs to the airport.
Sotosound
765
580
98
Buckinghamshire
Ian
Evening all.
Deco Audio in Aylesbury. James is a top class technician. Why not give them a call?
sculptor67
