Very Heavy Loudspeaker and amplifier Isolation
Minicoupeman
347
302
Sittingbourne
Andy Andrews
Ok. Not these but I tried washing machine vibration feet. For the cost, next to nothing, they were very good and remained in place for over a year. ( and I am old enough to have tried lots of other ‘solutions’.) Then I discovered ISOACOUSTIC. You get what you pay for.
hearhere
1,220
1,028
Portsmouth, UK
Peter
Vibration conrol for washing machines is a far cry from vibration control for speakers. Each needs its own control system and sadly these are not interchangeable. Don't put IsoAcoustic Gaias under your washing machine and don't put rubber cups under your speakers.
Reactions: hifinutt and TIU
TIU
Artist and daft as a brush
13,006
6,493
Birmingham
Gary
The same applies to any rubber gear. 🤪👹
MF 1000
Extreme Full Range 😱
6,145
4,676
Caego
Keith
With my bass units tipping the scales at 160Kg each tbh ive never felt the need for isolation as the weight kills any such issues.
hearhere
1,220
1,028
Portsmouth, UK
Peter
Only if the 160 Kg is cabinet weight with titchy little drivers! If you have 12" or 15" drivers in there, the enclosure will almost certainly benefit from good feet, or some other vibration control device. My own 95 Kg speakers have twin 12" drivers and the improvement in detail and control is very noticeable. If anything volume is very slightly lowered but the improvement in detail is well worth the cost. See if you can borrow some IsiAcoustic Titan Theis (up to 145 Kg) or Titan Rhea (190 Kg) feet from a friendly dealer. They do rarely come up used, so put a watch on HiFiShark and you may be lucky!
Chivas
878
226
58
Knebworth, Herts
I gave to agree. The Isoacoustic Gaias put an end to my research for effective isolation solutions
MF 1000
6,145
4,676
Caego
Keith
I need the PG Tips chimps to help me out moving the speakers to Stoke 😁😁
  • Haha
Reactions: uzzy
ziggy
644
607
98
Cardiff
This was my experience too. The speakers of the second system are on a copboard, far from ideal. The sound with washing machine feet was better than with cones, but Iso Pucks took it too a different level. Gave the Iso Pucks a try on the main system where I have proper stands and the improvement was similar. Must add that my speakers are NVA semi omnidirectional cubes which benefit from decoupling.
awkwardbydesign
Perfect, apparently.
10,376
2,132
Didn’t know Townsend had ventured into that world ……maybe even more gullible people playing concert grand pianos than HiFi buffs
And cellos, it works for them too. If you think about it, many players' platforms are basically resonant suspended floors.
Reactions: MF 1000
Tintinabulum
539
219
63
UK
I think the theory is that vibrations are caused by serious ground movement, lorries etc and all kinds of things. 160 kg is puny in comparison. Why is it the gullible using isolation rather than the naive not? Whoever said "you get what you pay for", disagree, somethings work, some thing don't, some DIY is very effective, some companies take the mickey cost wise, some are more reasonable.
MF 1000
6,145
4,676
Caego
Keith
My reference to gullible was in the context of devices costing £100’s rather than isolation stuff in general. I have used and do use isolation but Im not going to keep certain brands etc in maintaining their fleet of fast cars, country estates etc
Reactions: Strider and Tony_J
Tony_J
21,842
18,178
Bunessan
Tony
I think the fundamental problem is that people don't do the analysis based on what kind of floor construction they are dealing with and what kind of problems are present. For example, my listening room has a solid concrete floor sat on top of clay subsoil, and the house is sufficiently far from the nearest road (~100 metres) that subsonic vibration from traffic just isn't an issue and wouldn't be even if it was a suspended floor. So I don't need to isolate the (floor mounted) speakers from the floor - there are no external vibrations to cause a problem, and the speakers aren't going to make the floor resonate - what I need is strong coupling, so the speakers don't rock, which in practice is just a matter of standing them on adjustable feet - gravity does the coupling job perfectly well.
In contrast, in my previous house, we had Victorian wooden suspended floors which flexed considerably, and some kind of isolation would have helped to reduce the degree to which the speakers excited resonances in the timberwork. However, not all suspended floors have that issue - my study/workshop where I run a second system (also floor mounted speakers) is a timber suspended floor, but the floor construction is much more massive than normal, partly because it has a double layer of floorboarding topped by porcelain floor tiles, and it is pretty inert vibration-wise. Having the speakers directly coupled to the floor (adjustable feet again) works very well indeed.
Horses for courses - but it always helps to be able to distinguish between a horse and a donkey, and to tell the difference between a racecourse and a dog track (to mix several metaphors).
Tintinabulum
539
219
63
UK
I have solid concrete floor, screed on top. Over spec'd foundations into chalk. Rural Hampshire. When I isolated the speakers from the floor, their performance improved noticeably. They are 75kg each. I would imagine subsonic vibrations from from many sources, many miles away.
hearhere
1,220
1,028
Portsmouth, UK
Peter
My Urban Hampshire floors are concrete too (screed and timber over the concrete) and 19 floors up, so no traffic influence - and wind vibration is only about 1 c/sec!
I also found significant improvement in bass clarity and detail with GAIA feet fitted to 95 Kg speakers, compared with spikes onto spike floor protectors or directly onto heavy slate slabs.
Amormusic
2,961
2,354
168
UK
There's a thread somewhere on here with me trying lots of different types of speakers isolation on my last floorstanders. As part of this I tried washing machine feet. Fair do's they were the pick of the bunch of low cost solutions.
However, I then bought IsoAcoustic Gaia's and immediately my search and faffing ended. A country mile better than anything else. Just great.
I sold my speakers and Gaia's and bought standmounts. Then got rid of them and bought more floorstanders.
I have bought Gaia's to go on these. That will be done later today.
Particularly in the context of this thread, where I'll make a sweeping generalisation that heavier speakers are of greater value. Gaia's should not be underestimated as they are excellent and definitely worth a try ime. However, if the budget doesn't stretch that far, then washing machine feet are a low cost alternative.
Reactions: uzzy
akash011
