Having rediscovered the joys of vinyl with my recent TT upgrade, I have noticed that some of the older records sound a bit 'crackly' and, in some cases, a bit muted.
My vinyl cleaning over the years has been limited to running a "dust brush" over the surface [either the vinyl pad-type or fibre brush-thingy]. Styli I have tended to leave alone apart from a small soft brush to clean off visible accumulation (as and when, of course - I do keep my stuff cleaner than that probably sounds !
My thoughts have now turned to considering a more formal cleaning process for my 1000 or so LPs. Had previously heard about the big record-cleaning machines - looking around, i have noticed such animals as VPI, Moth and something alled Nitty-Gritty in the States. Frankly, all of these are outside of my budget, with lowest prices I have seen being some £200.
I remember discussing record cleaning many moons ago, in the heyday of vinyl and pre-shiny discs, when mention was made by some of warm water & dishwashing liquid then leaving to dry in the sun between sheets of glass to prevent warping - this always seemed likely to me to lead to damage and build up of more crap in the grooves over time due to the stickiness of the cleaning liquid than anything else.
I was also once given a can of 'Sonics Record Spray' to remove some unpleasant residue left on a hard-to-get 2nd hand acquisition - lets just say that didn't really prove entirely satisfactory - vinyl now no better than a frisbee and donor no longor an acquaintance.
Point of posting:
Is there a more affordable, realistic alternative which can be considered which will do a decent job and not actually just make matters worse? Whilst I would like to keep my collection clean, I am not going to be cleaning 200+ per week to justify spending 400 quid
. Maintenance of the collection is intended to be a slow and steady process as I revisit old favourites.
Any old hands with sound ideas to share / wisdom to impart / good kit to recommend (or move on at a price I can afford/ justify to myself?)
Kevin
Point of posting:
Kevin
