WAM Census 2021 Results - Speakers & Headphones
lostwin
Tinker Bod
2,469
2,473
Folkestone, Kent
For the penultimate set of results from the Census, we can look at the results in respect of the speaker and headphone question.
This was a thematic follow on from the previous question on amplifiers, so the question just read "And your speakers?" .  This was a multi select question set that aimed to capture at least 3 distinct attributes - not ideal for a couple of them, as I detail later.
Firstly, the aim was to capture the how the speaker was powered - passive to the various types of active. 226 responses were provided from 211 different respondents, again reflecting that more than one speaker or multiple systems may be owned by some.
78% reflect the traditional passive type and we have one wireless user. 22% of speakers are either partly or fully active, which I would suggest could reflect a strong emerging trend.  16 sets of speakers out there are active with external amps, which may well indicate a DIY route reflecting a number of such threads of projects of this type. No respondents solely use headphones.
Moving on to the type transducer method used, the number of respondents dropped off to 104.
Not surprisingly, cone type speakers dominate, but a decent number of panel speakers out there and even a few horns.
Limitations on how the question was structured play out in the following two charts.  Because there was no option for no sub woofer / no headphones, unfortunately it is difficult to judge the context for the affirmative responses. I have used the total 215 respondents as the basis for the following charts but strongly suspect  - particularly considering the drop off in response rate over the first two parts - that the affirmative proportions shown below are likely to be higher - you live and learn...
Firstly we asked who uses a separate sub woofer;
And then who uses headphones (within a HiFi context) and for what proportion of their listening time; Headphone usage.PNG
MF 1000
Extreme Full Range 😱
6,171
4,732
Caego
Keith
So I’m in the 5% who ha ve a fully active external amp setup and only 10% who have a separate sub …..does that equate to 0.5% 😁😁
  • Haha
Reactions: Tony_J
Tony_J
Gone fishin'
19,635
18,403
No Keith - you're more like 0.0005%... :D
No members online now.
