Sadly I have had a bad experience in the Wam classified's
I agreed to buy a Conrad Johnson ET6 pre amp and a Degritter RCM from the same seller.
The degritter was advertised as doing 550 cycles , When I received the unit it has done just under 900
And the Conrad Johnson pre has operating problems , It has bad hissing problems , Also I found out it is not a UK version it was imported direct from the USA so not covered by the UK guarantee , the fault ( hissing ) is not anything to do with other components In my system , If I swap the ET6 out no more problems ,
Tried for over a month to get it sorted with the seller who Is NOT responding to emails, phone calls, text's , or PM's through the forum , Also he has moved home now .
Be careful people , Trust in sellers needs to be investigated
