What can i do with some Mission 782's
nomismo
1,509
Central TV area
Splodge
I have a pair of 782's laying under my son's bed unused for nearly 4 years.
Now i've plenty of time on my hands and need a project to help keep the
grey matter working.
What's your thoughts on trying to improve them.
Replace crossover components for better ones?
Play around with damping?
I have already made a set of out riggers to give better stabilization.
Your ideas and addresses of component suppliers would be welcome.
hearingisbelieving
5,684
240
Bendorf, Germany
Had a quick google - cant be 100% as I dont know exactly which model/gen of the 782s you have but it says they are already side to side braced so not sure adding damping will help the cabinets - if you are bored you can always try though especially as it isnt expensive:
http://www.wilmslow-audio.co.uk/dedshete-panel-heavy-duty-286-p.asp
I would go for upgrading the caps personally. Try some of these:
http://www.cricklewoodelectronics.com/Cricklewood/home.php?cat=155
Also, dont foget to spend lots of time trying various positioning of the speakers themselves:
Distance from rear wall
Distance from side wall
Toe in
etc.
Have fun!
MeroA
