What is your ‘switch on’ ritual /process?
lostwin
Tinker Bod
2,456
2,426
Folkestone, Kent
So, just settling down and turning on the HiFi for the evening. I now realise that my switch on process is so convoluted that I’ll have to leave instructions in my will 😄!
First plug in the AC regenerator (the fans on idle are noisy, so keep unplugged). Then take the lid off the TT and stow half way across the room (away from sound reflections). This works as the regenerator takes 10 seconds to get going. Reach way under the rack to feel for the switch for the TT power supply. Next flick the switch on the Vida PS, then the valve pre pausing for a few seconds to hear the soft start gradually let the transformer hum emerge.
Then, if I’ve not played the system for a few days, I’ll delve behind the speakers to make sure the Velcro holding the external crossovers has not failed again…press firmly back in place.
Now to the John Wood KT88. I still find it an intimidating, frankly, scary thing. A check of the connection behind, no potential shorts?, then flick the power and stand back, it’s a bit like proding a dragon to wake it up.
……Wait 10 mins while the KT88’s warm through….
Still need to select an an LP, clamp it down, brush the stylus, sweep clean the record, cue the tonearm, lower the stylus….
….Set the pre volume
….Un-mute the VIDA
and if you are lucky, sound emerges…
You are all as bad, aren’t you?
newlash09
3,300
3,160
45
India
Y.Manohar / mike
I leave all my kit on.....everything. I just switch on my power regenerator, which takes about 5 secs to provide my wanted voltage and frequency. And then everything comes ON... but there is no way in heaven or hell that either my daughter or my wife can get a note purting out of these speakers . The system is too complex as it is. Iam already worried about how to word my will :D
Lurch
5,699
6,623
Chichester, W Sussex
Power Inspired Regen, Node2 and MLs are powered, up 24/7 so I run left to right. Lh Power amp, DAC + select input, DDC, Rh power amp. If intending to use CDP and/or TT, then CDP PS and/or Phono PS turned on. Amps are out of startup by then so straight to tunes from Node whilst phono and/or CDP warm up (both have valves in as does the DAC).
Sit down. Relax. Swear. Get back up again, walk across room to change input on Pre to Node as forgot I was listening to vinyl before I went to bed last night.
Strider
Nothing to see here
5,542
3,341
Slightly damp but willing to get wet.
Mark
The Rpi 3 with top hat I2S coax is always on into Cambridge Audio C840 DAC.
1st - Cambridge Audio 840C
The RPi4 with Kadas Toneboard always on.
Finally Rega Elicit R amplifier.
From my first days in recording, AV etc was never to switch on a source after you've switched on your amplifier(s).
Reactions: MVJ
Le Baron
Fully exonerated
2,793
3,940
Pays-Bas
Mouse, Mickey (Mr)
Why is this? For the record I do switch it on last, but that's just pure chance on my part.
maddog_007
maddog_007
982
1,427
Waterfoot ,Glasgow
dennis
….Un-mute the VIDA
My system is always on 'standby',just in case Vlad the Impaler declares War on Eastwood! 😉
  • Haha
Reactions: Le Baron
Strider
Nothing to see here
5,542
3,341
Mark
If the source does not use half decent muting relays or has a transient spike when switching on the line in/desk/amplifier/monitors/speakers could be damaged.
Just something I was taught and still adhere to.
lostwin
Tinker Bod
2,456
2,426
Folkestone, Kent
@lostwin Which regenerator are you using? Get a completely silent Puritan PSM156 which can be left plugged in.
One of the older Power Inspired units. Having checked the manual, it seems there is an adjustment to reduce the fan speed that I will try.
What the manual didn’t say - and what I was checking for - is whether as regenerator like this removes any incoming DC on the mains, I assume it would but still not sure.
Edit: much quieter (virtually silent) now that I have reduced fan speed.
Reactions: leenorris78
ziggy
644
607
98
Cardiff
Switch on the Sbooster attached to streamer, everything else is on stand by. Wait a short while for streamer to boot up. Select BubbleUp app on my phone. Go to Qobuz or My Cloud, select artist, album and play.
Reactions: MVJ
Tony_J
21,829
18,140
Bunessan
Tony
On my two active systems the miniDSP units act as preamps and are always on, but on the 3-way system there is a secondary 2-way analogue crossover that absolutely must be switched on before the amps (and switched off after them) to avoid nasty thumps. The R-Pi based streamers are also always on.
23joggler
