What's a Raspberry Pi Streamer Worth?
garn63
12,278
18,695
198
www.avfc.co.uk
They wouldn't get my business if they thought that pulling a fast one was o.k. The guy that 'does' the figures will like it when one is ordered though.
slavedata
949
612
123
Bottesford Melton
Dave Slater
Well, in the link, it reports that the rpi is being used as an "internet gateway device".
So relax ;)
ronnie
That's exactly what the Pi always does. So all they really add is their DAC and a bought in switched power supply. Oh don't forget the lovely case milled out of a large lump of aluminium.
Reactions: greybeard
tuga
14,332
6,997
Oxen's ford, UK
Ricardo
This is the £1.5k Holo Red:
rdale
2,806
1,773
178
Gran Canaria, Spain
Richard Dale
And the Pro-Ject Box S2:
It's not that uncommon...
I have a Stack Link with a CM3 Pi compute module very similar to the Pro-Ject above, and an Allo USBridge Signature which also uses a CM3. I think it is easier to optimize the power supply with the compute modules than it is when you use a full blown Pi.
Reactions: tuga
Cable Monkey
9,067
2,084
Birmingham, UK
Henry
Just an addendum to this subject, pretty much any streamer built more recently is designed around a compute module of some type. Our familiarity with the Raspberry Pi module and the low cost of the SBC evaluation board makes us somewhat cynical but it is a sensible way to do things because failed memory or storage doesn’t result in a dead streamer. Open up your flagship Lumin U2 or even one of the Eversolo streamers and you will find a compute module at its heart. Just not one you are so familiar with.
Oh, and the Holo Red isn‘t 1.5k. It’s around half that and can literally run any software designed to run on a Raspberry Pi platform.
Reactions: bobovox
