Which speaker cable? Primare and Dynaudio
djve
4
UK
Sorry if this is in the wrong place.
I have a Primare A32 driving Dynaudio Contour 1.8mk2 speakers. The left speaker is 3.5m from the amp, the right 1.5m.
My budget is around £400 for new or used speaker cable. Any suggestions?
uzzy
Grumpy Old Git
8,246
4,112
NN38TA Northampton
First off as the electric signal travel at almost the speed of light the different lengths will make no audible difference. However to stop your mind playing games get the same length for each side. As to a £400 budget .. well if it was me I would take a nought off and get these which have over 500 strands of OFC cable
Product Code: 992012​
Speaker Cable image
4.0mm (511/0.1mm) 2Core Parallel OFC PVC Clear Speaker Cable​
More info...price per meter
1-4950-99100+
£1.98£1.70£1.58
https://www.electriccable.co.uk/RWDspeakercableTECC10.php#TECC10
I have been using similar for over 20 years now (30 foot lengths) on my Art Impressions (using an Audio Research SP9 and a Hafler DH200 and or 220 power amp.
  • Sad
Reactions: Fullrange
Sotosound
718
524
98
Buckinghamshire
Ian
Are you likely to move things around in the future?
A little too much cable won't cause any harm today but might save you some cash in the future.
Also, exactly what do you mean by "3.5M from the amp"? Is that a nice neat and discrete cable run or a point-to-point straight line?
djve
4
UK
I'm not likely to move anything. But it probably help resale value if it same length. The 3.5m is a nice neat cable run.
Reactions: Sotosound
Sotosound
718
524
98
Buckinghamshire
Ian
Many thanks.
The terminals are close to the floor on your speakers.
It might be worth allowing for a future change of floor-stander wherein the terminals are positioned much higher.
Just a thought....
Reactions: djve
djve
4
UK
Many thanks.
Just a thought....
I won't be replacing the speakers. I'm happy with the sound of them.
Lawrence001
4,747
2,284
168
Lawrence
Speaker Cable image
1-4950-99100+
£1.98£1.70£1.58
I'm not sure it's the speed of propagation of the signal that causes longer runs of cable to sound different...
Jezzer
Passionate
9,845
1,281
Uxbridge
Jezzer
Nice speakers. I had a pair driven by a Krell KAV400xi amp and used Chord Co Odyssey cables to good effect. These days I use Tellurium Q Black II which are excellent.
Reactions: djve
34,722
It isn't, or won't be.
Any audible differences between speaker cables (and any other wire) will be effects that directly relate to the electrical/physical properties of the cable. Things like inductance, resistance and capacitance will vary depending on the length.
The most compelling argument for having same-length cables, however, is that they're massively easier to resell.
uzzy
Grumpy Old Git
8,246
4,112
NN38TA Northampton
I see Fullrange was sad at my response - as my chosen leads are inexpensive perhaps he would like to try some and confirm they actually make him sad.
If I win the lottery and have ten grand to waste I might get some Dram Silver cables (made using Kondo silver wires) for mine as they did sound a tad clearer and faster than my usual cables.
lazycat
2,940
4,609
Gloucestershire
simon
If you have a local hifi dealer it may be worth asking if you can borrow a few pairs of different cables. Prob have to put a deposit but...
IME cables didn't make a difference until 4 yrs ago when I tried some NVA on sale/return.
With my Denon amp they just made a silly difference. I still can't believe it. But with my previous Exposure amp they made no difference whatsoever.
@rabski has it right, differing properties will affect amp/speakers er.. differently.
Try before you buy, if poss.
toms wait
3,611
Greg
I have a pair of Van Den Hul CS122 that you can try, a 4.5m and a 3m terminated with banana plugs. These are the hybrid ones. Clean and working. Lots of good and indifferent reviews, to me they are very even handed not bright and will tame a bright system slightly.
PM if interested
Marenn
