Who makes a good 5 pin DIN to 2 RCA cable ?
Pure_Carbon
948
213
58
Englishman in Wales.
Lord Lucan (Oops...)
I've been using a borrowed cable from a fellow wammer to connect my Opus 21 to the pre , and belive there is an improvement, so would like to buy a decent cable.
I've seen several Chord Co. versions, would am not a fan of their products.
Any other suggestions ?
Thanks.
unclepuncle
14,697
488
Northants
I think Kimber (Russ Andrews) do them, they certainly do DIN cables - might need to be a special order for Din - RCA though.
M
MJ.
We have 2 very capable (and cheap (don't ya know it ;-) )) cable capable guys (sodders and ReferenceFidelity) on here. Support your local traders; go to them first :)
The Strat
14,031
144
123
Buckingham, UK
Lindsay
Well the guys as mentioned on here have a great reputation but i've got a Chord RCA>DIN for my Tuner and it's fine.
M
Mike P
Hi Neil,
Glad it works! Pretty much any cable from any decent manufacturer can be terminated as DIN-Phono. I had my Kondo KSL-LP re-terminated as such when I bought the new setup. Kevin was adamant that it was better than running the Opus out of the RCA's so therefore worthwhile doing so.
BW
Mike
graham67
3,738
1,032
there is another option you might consider. Ian Fraser who also sells on the bay has made me several din cables for my quads. Using high quality PREH plugs (Neutrik for RCA) and van damme or meridian digital cable, the price and quality for the finished product makes most commercial cables look just plain silly. he is a very accomodating and helpful person to deal with and i recommend him
These are the cables he made for me, just tell him your needs and he will make a cable to suit.
Down in Devon
134
15
Now Up Norf
Mike
The Missing Link would be my recommendation...Mark and Jan are true stars...You could get a loan cable and make your own mind up...
Frizzy brizzy
656
5
New forest
Laurie
Having used definitive and the missing link I can heartily recommend both, though the missing link will probably not try to sell you a uber expensive audio niknak that you somehow never needed previously. But after buying cannot live without.
bandit pilot
Comfortably Numb
15,412
3,065
North Nott's
Rick
I've got some Purite IC's here and they are excellent value with quality products used in the manufacture. Nothing I've heard better at any price, first class service too. :^
greygoose
205
46
43
Ireland
I have a definitive cable for my opus 21, what was the niknak, sounds good:D
NAM
5,051
80
Edinburgh, Scotland
Neil
Is this a cable thread, could be dangerous stuff.
Not really. It's just that 5-pin din to rca aren't the easiest to find these days, at least they weren't when I needed them to connect sources to my old creek amp. You can't pick them up for a couple of quid in tescos, or even maplins, as far as I know. At the time I bought mine Flashback Sales were the cheapest ones I could source after an extensive hunt.
brandonfin
