Hi All,
Have recently bought some Totem Rainmakers to pit against my Sonus Faber Concertino's, and I'm using a Hegel H90 with Tellurium Q Black 2 cables. Have a couple of REL T-zero subs too, and they are run on high level via banana plugs whilst the main speakers are spades.
The Totem's are bi wire capable (unlike the Sonus), so I feel I should probably do them the courtesy of trying it out.
So as far as cable is concerned I'm looking for something that would be similar in quality/performance to the Tellurium Q Black 2, but obviously bi wire, and at least 2m long.
As far as advice is concerned, I'm enthusiastic but not very knowledgeable, and one thought I had was just to buy another matching pair of the Q's with spades like I already have, and them sandwich them both together at the amp end. I can't get my head around if that's a good idea or not, if maybe it would hinder the signal somehow, so I was wondering anyone had any input on that?
Many thanks in advance, quite happy to entertain suggestions as to whether even bothering with bi wire is worth the effort
