What do we music lovers need to know about Yes?
Well, the first two albums can safely be ignored. Number 3, The Yes Album, introduced the remarkable Steve Howe, but its production is inadequate and the four strongest cuts are repeated on Yessongs, so there's no need to buy it.
Rick Wakeman joined during the making of Fragile, and it's a slightly flawed Prog masterwork. It's the first Yes album that you need. The track South Side of the Sky must be one of the band's peaks.
Then comes Close to the Edge, which is a Prog classic. It's all repeated on the live album though, so it's not the first to buy.
Yessongs is the live one, and has songs from The Yes Album and nearly all of the substantial pieces from Fragile, plus all of CttE. There are longish solos, but as a 1970s live Rock album it stands out for its ambition and accomplishment.
... Next up there's Tales From Topographic Oceans. Few records have divided opinion like this one. I'll just offer the opinion that the band was really trying to offer something special here, and for me they succeeded in spades.
Mr. Wakeman thought otherwise, and he quit. His replacement Patrick Moraz played a large part in the making of Relayer. Herein lies the band's masterpiece, The Gates of Delirium. The other two songs amaze and soothe by turns.
Jon Anderson then recorded Olias of Sunhillow, an enchanting and sporadically wonderful thing that Yes fans should revere.
Lastly there's Going For the One. RW has re-joined and much of the music is as magical as it should be.
After that, there are decades of guff.
So, if you're curious about the Prog genre, I'd recommend all of Yes's albums from Fragile to Going For the One.
