O venerable druids of hi fi, your wisdom please. I’m currently auditioning for purchase two very good integrated amps to drive my Shahinian Obelisk Mk2 speakers.
The Obs, while rated at a nominal 6 ohms, are known to be difficult to drive because their omnidirectional supertweeters dip and hover around the 2 ohm mark.
I understand that wattage is secondary to current when it comes to an amp’s ability to handle low impedance speakers - but when I get into comparisons between the two amps I start to struggle.
Below are the power specs for each amp, benchmarked from the same source. For fun, and to keep things as objective as possible, I will for now avoid revealing the identity of the two amps and simply call them A and B.
Amplifier A: Rated 100/200w into 8/4ohm
The modest 100/200W 8/4ohm rating is exceeded to the tune of 190W/310W, with 228W, 433W, 645W and 355W achieved under dynamic conditions into 8, 4, 2 and 1ohm loads.
Continuous power (<1% THD, 8/4ohm) | 190W / 310W |
Dynamic power (<1% THD, 8/4/2/1ohm) | 228W / 433W / 645W / 355W |
Amplifier B: Rated 80w/160w into 8/4 ohm
Load tolerance is exceptional, with its 80W/160W 8/4ohm power rating being met at 2x93W and 2x180W into 8 and 4ohm loads. This 'stiff' PSU means that while there's little additional headroom under dynamic conditions there is the current available (24.9A for 10msec at <1% THD) to support a full 95W, 184W, 346W and 618W into 8, 4, 2 and 1ohm loads, respectively. So tough speaker loads will be driven with comparative ease.
Continuous power (<1% THD, 8/4ohm) | 93W / 180W |
Dynamic power (<1% THD, 8/4/2/1ohm) | 95W / 184W / 346W / 618W |
SO, Amp A doubles into 4 ohms, but beyond that starts to drop off - whereas Amp B doubles into 4 ohms and 2 ohms and has a decent stab at doubling to 1ohm!
BUT, at 2 ohm Amp A is putting out 645W, while Amp B is putting out 346W.
So my question is: which will cope/perform better with low impedance dips? In practice, does the superior underlying current stability suggested by Amp B trump the fact that Amp A can put out double the wattage of Amp B at 2ohm?
Any thoughts from the more technically minded among you would be very welcome. I am of course comparing their actual, rather than theoretical, performance at present and will share the results in due course – but I have to finish burning the buggers in first! Also, understanding the above will help me put in to context what I'm hearing.
Cheers
Steve
