Thanks indeed FatM. I should have a 1st try today or tmrw: waiting on resistors at the mo.The original Epos tweeter wasn't reversed, so it's likely that you won't need to reverse it. I'm just trying to cover all possible outcomes.
I think the wrong polarity might mean the voicecoil working inwards, rather than outwards, in its recess. If so surely this would be audibly incorrect.
Cheers, Abbot
Got resistors, but forgot i ran out of solder.. urgh, this wait is a ballache! apologies.Exciting! Just don't be too disheartened if they sound bad. It will be purely down to the crossover, and should be fixable.
Reverse polarity is sometimes the correct polarity.
In meantime, my 7 watters measure 7.2r & 7.3r.. 5% tolerance so I think this is ok? 3.3uf caps I have.
Trying to glean what more I can from the chart above; is this the stereophile chart.. or is it my woofer's curve, plus the morel tweeter curve ontop? Or can these two curves only actually be measured, once I get them in with these cap+r's in place?
Thanks, Abbot
That's good then: so I've got 5.6r 7w on their way, & 2.2/250 film caps (& some 6.8r's & 3.3uf too).You won't hear the difference between 7.2 and 7.3R resistors, and 3.3uf caps are fine. 250v caps are also fine. A lot of speakers have 50v caps in, but that's about the lowest you'll find.
The chart above is just the Stereophile measurements, showing a possible scenario (dip in frequency response with the wrong polarity). The only way to know exactly what's happening with your Morel tweeter, would be to measure, and the only way to model a crossover properly is to measure the drivers in the enclosure, without any components connected.
So a few to do innitial 'tests' here.
Ah so, if I were to bring over (I'm actually in broadway in a month 6/09 to see my oldies for a few days.. but may not be suitable for you) you'd want with cap & resistors removed 1st ( kept with them: i mustn't forget!).
Thanks, Abbot
Hi FatM. Got tweeters etc in. Had first listen..Yes, best to remove them before bringing them over.
I would/will just use the binding posts on the back of the speaker for testing components.
That's good to hear. If the tweeter is a bit low in level, that could cause the lower mids to sound a bit bloomy. You could try a lower value resistor to bring up the treble level, to see if that helps.
I agree that it does look like the tweeter is the weak link. It looks pretty bad on paper at least, and I'm not a big fan of metal tweeters anyway.
Give them a good blast and see what you think. You should never evaluate speakers at low volume. IIRC my old loudspeaker design book recommended around 90db.
@Fatmarley More judgement after some fair welly, thus;Good then I'll pop in the 5.6r's next I think. No I need a bit of vol/ welly to get past my ear hair spriggots.
Abbot
I think maybe the tweeter is both a tad bright/ thin, as well as the tad of bloominess to midbass. Only a tad really, as far as my clothears can establish.
Would How about a bit less r @ 5.6r & a bit less cap @ 2.2uf? Am I barking up the right tree?
Thanks, Abbot
Understood. My spkr cable plugs such a pain to refettle at the back to do this tho, its almost as easy to redo on back of the tweeter. Thank goodness only 2 components!This is where it really helps to have measurements.
I honestly haven't a clue what to suggest. It may be best to write down what you've tried with a description of the sound, and just keep trying different combinations. This is the reason why the crossover is best on the outside, it just makes if far easier to experiment.
Hi Lawrence. This is valuable information & seems sensible. You can easily fool yourself too hearing what you want, not what's avtually there I'd say too.Word of advice, tuning a crossover by ear is hard work as you need to know what you're doing (ie. have experience, although trying to work it out from trial and error is an interesting exercise) and once you've got it relatively close, which it sounds like you have, you have to spend longer listening to each tweak to understand how it sounds.
As @Fatmarley says having an exterior crossover, at least temporarily until you have finished tuning, is a good idea. As well as convenience, I'm not sure how the screws in the ES14s are but if they are direct into the wood (unlikely with such well made speakers) eventually it will wear out the holes.
Am I right in thinking the bass speaker is run full range so you are replacing the original cap with a cap plus resistor to pad down the tweeter? I'd start with the same cap as before plus an L-pad to get the right level, which can then be fixed once you've finished.
