Could someone quickly measure the distance between Technics SL1200 feet for me?
Phil Bishop
211
153
As the title suggests, I'm looking to get a new Technics SL1200 or 1210GR and have it on a wall mounted shelf. I'm pretty sure it will fit fine but don't want the feet overhanging the shelf. So, can someone who has one measure the distance between the feet from the outside of one foot to the outside of the other? Hope that makes sense?
Cheers!
Reactions: MVJ
MVJ
Mummies little ray of sunshine🖕
19,216
40,043
198
Guiseley, Leeds,
Steve,
Cheers!
Hi Phil, I have a new Technics SL-1200G & the distance you need to know is 44.5cm left to right and 34.5cm front to back hope that helps you👍
The photo's below show it standing on a shelf 50cm wide & 45cm deep click photo to enlarge👍
A858DF5B-402E-4650-B682-3124CE1E4F07.jpeg 53AB856F-FC49-4F8C-89AD-B4D5E0EA30B4.jpeg
JezR
818
369
Brighton, UK
Jez
The dimensions of the plinth are W 453 x D 372 mm and the feet are just inside by about 5 mm from the edges, so as a ball park figure for the shelf surface would be W 443 x D 362 mm plus you would also need to consider the lid moving back as well, my lid is not installed so I can't measure that.
I out at the moment but can confirm later with a tape measure.
Reactions: Phil Bishop
Phil Bishop
211
153
Lovely, I'd love to be able to afford a "G" (y)
Reactions: MVJ
JezR
818
369
Brighton, UK
Jez
I see MVJ has given you some measurements so I won't do it now ( still not home yet )
Enjoy your new turntable whatever you decided on.
filipm
