I'm not really clued up on these, I assume they offer a better quality conversion than the internal one? what do you look for in a good DAC? and how do you know from the specs whether its better than the internal one you already have?
I wanted earlier in the year to go back to a one box solution and now ended up with . . . . . . . . . a three box solutionSeperate dacs are superb, as mentioned you can hook up multiple digital sources etc.And I still think there are pro's and con's to both one and two box solutions.
Agree - I've hooked up my PC via Optical into my MD deck and used it as a DAC. It sounded very very good - I was pleasently surprised with the results. It also elimated any RFI that you'd get via analog, although using a good shielfed cable definately helps, as I've also got great results viaa decent3.5mm to phono cable.Seperate dacs are superb, as mentioned you can hook up multiple digital sources etc.And I still think there are pro's and con's to both one and two box solutions.
That one box sollution is exactly what I have been hoping to achieve, now with two kids , a smaller house and less space I had asspirations of some sort of Esoteric CD/DVD transport-Tact 2.2x-ATC active with a nice balanced in-out phono stage for my turntable, and even thought of replacing all the Mana with a solid lockable unit.Sastusbulbas wrote:I wanted earlier in the year to go back to a one box solution and now ended up with . . . . . . . . . a three box solutionSeperate dacs are superb, as mentioned you can hook up multiple digital sources etc.And I still think there are pro's and con's to both one and two box solutions.
The DAC comes in two sections each with their own independant power supplies, one for the digital decoding and the other for analogue output with an umbilical cable between the two. Valve output too and it does sound half tidy now I've swapped a few components over. Compared this setup against an Ayre CX7 cd player and an Esoteric X-03 andit gotbeaten by a small margin before the modifications,but after the mods I very much doubt it.
