Having gone to Scalford I was really inspired and really amazed what can be achieved at a relatively low cost. Yes, the Linn + PMC (in Sunbeamgls's room) wasn't in the low cost category but the level of clarity I've heard haunts me To that extent that I'm considering wholesale changes to my system. If I can at least go some of the distance at a low budget, I need to try.
In a way it's to limit perpetual box swapping with usually unknown results. But also to future proof my setup when and if I move (whether room or a house).
I'm considering a diy digitally room corrected active setup. And no, nothing that's readily available on the market so bear with me. The aim would be to achieve all of it for no more than a £1,000 source excluded. It would need to allow flexibility so I can expand if I wished. I've never undertaken anything like it so would like your input.
Until I know this will 100% work and that I will enjoy the effects I don't want to plough money into it. So I'm considering doing it in three stages. That would allow me time to learn and slowly make changes as my ears adjust.
1) TESTING... Use a UMIK-1 (circa £100) to measure and take out a two week trial of Dirac Live to see how much can be achieved with my existing setup also have a pair of QLN Qubic 122 (floorstanders) that I'd test and use for this project. I'd be particularly interested on impact of different speakers and amplification on the end result. Would
2) EXPERIMENTATION... Buy Minidsp DDRC-24 (circa £450) as a 2 way active crossover / room correction solution. Would use both pairs of speakers. At that stage I would not remove passive crossovers. Using standmounts as mids and highs (HF) and getting bass (LF) from woofer on the floorstanders to add extension. To do that I'd need amplification. I'd probably use Sony STR-DB930 (sub £100) as one box solution. Individual drivers don't require as much power as passive speakers. I understand I could connect LF to back speaker terminals and HF to fronts.
3) IMPLEMENTATION... Depending on results above I'd either keep existing speakers and remove passive crossovers or buy and re-purpose a second hand pair of floorstanders or transmission line standmounts. Two way IPL floorstanders (sub £200) or some older PMC (max £350) but would remove passive crossovers. If I'd manage to go with cheaper speakers I could diy some acoustic panels for about £100 or if need be upgrade the amp to something like a 4/6 channel power amp. I've seen some Rotels for little money.
So once completed the chain would look like this
Preamp streamer -> (digital stereo signal) -> DDRC-24 (working as active crossover + room correction + dac) -> (2 x analogue stereo signal for HF and LF) -> at least 4 channel amp -> 2 LF channels to drivers + 2 HF channels to tweeters
Any thoughts? Are there non minidsp (similar budget) alternatives to DDRC-24? Have I missed anything or made a wrong assumption? Is there a better way to do it that's withing the budget?
Thanks in advance for all help and participation in this thread.
