I am just about to start a new project which is listed on here of converting a pair of KEF 103 Reference (1976 - 1977 Model) . In the main I am going to by pass the passive crossovers and use a Minidsp unit to generate both a full digital active crossover and also DSP room correction filters.
As I am using an existing model there are certain things that I need to change . One I need to have an additional pair of speaker inputs added to each speaker so that I can connect to the Treble and Bass units directly . To do this I need to get inside the speaker and I have some general questions that i would like advice on .
The KEF units have a heavy metal frame inside the wooden sides which makes the cabinet both heavy and stiff . There is also some thin foam tape around the driver fixing frame which seals the cabinet when you tighten the frame back in as this is a sealed baffle unit. Can you buy this black foam tape to replace it with new or would draught excluder tape (thin black stuff with adhesive back) be suitable ?
Then my main question for advice is insdie the cabonet there is wadding / stuffing material I presume to dampen the space in the enclosure . Is it best to remove this , essentail so I can get access to the speaker binding / 4mm Plug sockets and then just try and put it back as close to what it was ?
I have read that some speakers of this time were over filled and there is a sonic advantage to reducing the amount of filling in the cabinet or in at least two extreme cases it was suggested that the filling could be removed altogether .
What have you all found when making your own units ? Did you use any stuffing inside the cabinets ?
