Looking for a bit of guidance for something I am thinking about looking at but not just now . I have recently done two projects with passive speakers converted to active (Monitor Audi and Kef 103 Reference) . In the most part this went well and did not task my technical and practical skills too much .
I am now considering trying something that will I know be a little harder. I was looking to keep my eye out for a decent pair of 12 " Tannoy Dual Concentric Speakers . Now in an ideal world I would be able to get a pair already mounted in a sealed unit but more likely to get a lower cost option of just the drivers.
Now Tannoy Dual Concentric Drivers look like they are single units but as I understand it they have a tweeter in the center of the Bass Driver so in fact are two way units with a crossover. What I want to do is use the MiniDSP DDRC24 to replace the crossover and make the speakers active. Then look for a DIY cabinet plan to construct for a sealed baffle design .
What I need to understand and hopefully I can get help with is are the Bass and Treble connected separately and is is easy to split the wiring so that it can be connected to a pier of Bi Wire posts on the rear of the cabinet ?
Also does anyone know of any current DIY designs that are sealed baffle that work with these drive units.
Any advice , abuse or even sympathy would be appreciated.
