I must warn you about something on the subject of what is now the default procedure for clearing wax, as syringing is now seen for the risky process it can be with too much leading toward advanced hearing loss issues. Micro-suction, as it stands, works, but recently I have had something go wrong on a procedure carried out local to me at my new address here and am seeking legal counsel against a practitioner using cheap rubbish for micro-suction that has permanently lost my RH HF above 3KHz, where previously I could hear to around 15KHz, and I am 58. This will be the subject of a thread if the ball gets rolling to a successful end, - which I wholeheartedly intend it to. Be warned, cheap, plastic portable machines from visiting audiologists, (probably not even CE marked at that) are lethal with shrill resonances emanating via the crappy plastic tube they insert down the ear canal during the procedure; unlike the precision-engineered laboratory standard instruments used on permanently installed full-sized apparatus, as previously facilitated by a London-based specialist operation of note at London Bridge that I'd attended.
