A bit of background to my office system.
Initially it was just a headphone setup using a Helot valve headphone amp being fed by my iPhone.
The PC had its own active speaker system, a JBL Creature that I’d had for many years.
The Creature eventually stopped working and needed to be replaced. I now looked at having one system for both, rather than getting a new system just for the PC.
To that end, got an Icon Audio Stereo 25 MkII valve integrated amplifier, which had a headphone socket. Connected the PC to this using the Khadas Tone 1 and connected the iPhone using DacMagic 100. Added some Q Acoustics 2020i speakers to complete the system.
Now after a couple of years, I have found that don’t connect the iPhone anymore and just stream from the PC using Qobuz or Jazz24. It is also used for the general sound from the PC. Additionally, can’t recall when I last used the Focal Listen Pro headphones.
Now with the faulty DacMagic100 has made me consider as to how I use the system;
- Don’t use the headphones, so don’t need a headphone socket
- Can sell the headphones
- Only need one DAC
- The amp is really too big for the desk, need more real estate back
- Don’t need high end audio as is used for the PC sound and for background music when working in the office
So what are my options; Looking to get a smaller integrated amp after seeing the size of the Topping D10s. And don’t need a headphone socket?
So looking at smaller desktop amps and considering;
- iFi
- Topping
- SMSL
Also looking at getting an amp with a built in DAC. After doing some research, I like the look of the SMSL SA300. This has a built in DAC with a USB input and a RCA input, plus is titchy compared to the Icon Audio, even with speaker binding posts. The reviews I’ve seen on this do look rather good.
Part of the rationale behind this is, the PC can connect directly to the built in DAC. I can then compare this using the Khadas to see which is better. This way, I can also keep my existing cables which keeps some of the cost down.
If this doesn’t work out, next on the list is to try the Topping MX5 Amp / DAC.
If all works out OK, I should have;
- More desk top area
- Reasonable sound from the desktop system
- Sell the Icon Audio Stereo 25 MkII amp
- Sell the Khadas Tone 1 DAC
- Sell the Focal Listen Pro headphones
I must admit that I am enjoying playing around with this system, it is a bit of fun. Also it’s giving me the opportunity to re-organise my office desk and work space.
DG…
