14 hours ago, ANADROL-50 said:
Is the Kimber Kable 8TC speaker cable really this good or is this review just nonsense ?
Is this because the output of amplifiers and the input of loudspeakers varies hence there is no one single perfect cable design ?I've got a pair of the 8TCs and yes good cables but it's never that straight forward. Mostly depends on what the cable is connected to at both ends.
This product should be better i guess as it uses silver instead of copper :-Check out the Gothic cable also it has similar windings
My browser says that link can't provide a secure connection.This product should be better i guess as it uses silver instead of copper :-
https://gothicaudio.com/collections/litz-cables
It's a capacitor.Is the Kimber Kable 8TC speaker cable really this good or is this review just nonsense ?
As I guess are all cables to a greater or lesser extent. The same guy who did the video has published his measurements - see link below. Whilst he admits the capacitance is somewhat higher (as a side effect of the low inductance) he concludes it should not be a problem for any competent amplifier and with normal speaker cable lengths.It's a capacitor.
The capacitance is spec'ed at 346 pF/m, definitely too high for my amplifier.As I guess are all cables to a greater or lesser extent. The same guy who did the video has published his measurements - see link below. Whilst he admits the capacitance is somewhat higher (as a side effect of the low inductance) he concludes it should not be a problem for any competent amplifier and with normal speaker cable lengths.
I have some 8TC (although not in a system at the moment) and it seems to sound fine.
https://www.audioholics.com/gadget-reviews/kimber-kable-8tc-speaker-cable/measurements
The chap in his measurements section says, “The Kimber 8TC and 8PR cables exhibit about four times higher capacitance than standard 10-12AWG zip cord, and twice as high as its 4PR sibling. Again I don’t see this as a show stopper especially since most people purchasing these types of cables are doing so for short runs (under 50 ft) and are likely using high quality amplification that doesn’t have stability issues driving moderately high capacitive cables.”The capacitance is spec'ed at 346 pF/m, definitely too high for my amplifier.
That's 10x more than a regular cable, 20x more than a low capacitance cable.
"About four times"???The chap in his measurements section says, “The Kimber 8TC and 8PR cables exhibit about four times higher capacitance than standard 10-12AWG zip cord, and twice as high as its 4PR sibling. Again I don’t see this as a show stopper especially since most people purchasing these types of cables are doing so for short runs (under 50 ft) and are likely using high quality amplification that doesn’t have stability issues driving moderately high capacitive cables.”
https://gothicaudio.com/collections/litz-cablesMy browser says that link can't provide a secure connection.
But now you've got and SME the differences will become clearIt's a cable, some amps and speakers don't like braided ones. I found no difference between it and £3 a meter van-damme
The 4TC has just over half the capacitance of the 8TC, which is why there's less roll-off of the treble.It's been a few years since I tried 8TC. Must admit I found it a bit safe and tbh boring.
Dynamically it was noticeably slow to respond to low level transients and seemed a bit uninteresting and laidback rhythmically. Top end seemed a little rolled off, closed in. Not particularly transparent.
To my ears the 4TC was better; faster, more agile if not having the bass weight of the 8TC.
