For those interested in the process of the Organik DAC and Utopik power supply upgrades I thought I would share a bit of the upgrade process. The nice thing about the modularity of the SDSM is allows for these types of upgrades without having to sell a perfectly fine component to help purchase a new one.
Image 1: My pre upgraded SDSM with the original power supply and a line output card with the Katalyst DAC that came with the unit when I purchased it new. Technically and sonically, nothing wrong with the setup - I just decided to take advance of the upgrade offer. Take note of the small black box by the dial with the air slats in it. This is the original power supply and it will be very obvious once Utopik is installed.
Image 2: The Utopik power supply waiting to be installed. There are two connectors on the bottom of power supply that delivers power to the system. It is clearly larger and heavier than the orignal PS that came with the SDSM.
Image 3: The original power supply removed. I was rather surprised at the size difference between the two units.
Image 4: Utopik installed. Compare to image 1 where the Utopik occupies the space up to the HDMI board (shown on the bottom left).
Image 5: Here we can see the analog 2 channel card removed from the system with the Katalyst module still installed.
Image 6 & 6a: Simply a closeup of the Katalyst module and how the analog output cartridge appears with the DAV module removed. Note the the little white arrow at the top of the 2nd image. With Katalyst this aligned to another white arrow in the bottom of the module. Also note, Katalyst is "right reading" in this view. The Organik module is just a touch different.
Image 7: The Organik DAC module in all its glory waiting to be fitted. I would be curious how the layout of the board or what aspects of this module are different from other implementations in the Linn ecosystem. If anyone knows please chime in.
Image 8: Just prior to closing the SDSM back up and placing it back in my system for the first Organik/Utopik listening session.
My next post will be on initial listening impressions. More to come...
