Cross posted, thanks for your reply. Yes, this is of course a measurement of just one speaker not a stereo pair.@Camverton I've just spent a bit of time trying to see if I could work out what's going on better in terms of the ETC changes you've seen. I can't see anything like 15 dB reduction you've seen but I can see some peaks reduced by up to a couple of dB, and a smaller number actually increased in amplitude with DL on. I'm sure this is all tied up with the changes to the impulse response shape, how surfaces reflect different frequencies, and how the contributions of multiple reflections all sum up. It's complicated! Definitely something that's made me think but it still remains a physical impossibility for DL to reduce boundary reflections.
Just to check actually, your 15 dB change is for a single speaker measured on it's own I assume? Rather than two playing together?
Just to be clear the mathematics involved doubtless require a far better brain than mine and it is indeed complicated so I speak from what I have observed (and hear) rather than knowledge of how it works. Do bear in mind that the 15 dB reduction is when using an omnidirectional speaker which is likely to be more affected by dirac.
Current setup in my main, arguably too lively, room is dirac up to 99 Hz with SHD handling crossover at 40Hz from SVS subs to German Physiks omnis positioned over 2 metres from the front wall and slightly less than 1 metre from the side walls. The speakers are positioned to give the most realistic illusion of having a performer in front of me, although that is not the best position for even bass, hence the subs and use of dirac. For small scale ensembles or tightly focussed soloists I have a slight preference for using dirac. For large scale orchestral music the reverse. It’s all about the illusion, and wonderful to have a choice - cheaper than changing components!
