As the driver size question came up I'll say that personally I think bigger is probably generally better...
In terms of personal experience I've owned three subs; two with 12" drivers and one with a 15" driver. Here's a comparison I posted on another forum of a 12" ported sub (BK Monolith) and a 15" sealed sub (Power Sound Audio S1510), which covers music first then movies:
https://www.avforums.com/threads/po...ry-of-mojogoes.1953630/page-168#post-27814740
My main speakers are 2-way with 6.5" bass drivers. I high-pass filter these so that frequencies below 110 Hz go to my 15" sealed sub instead, because it sounds better. There's more to this than driver size but it's not like the big driver is an obvious problem or I wouldn't do this!
From a theoretical perspective there are good reasons to use large drivers for low bass. If there is a single, small driver trying to generate low bass it has to move in and out
a lot to generate any meaningful sound level, and bass extension is also limited. Generally such high driver excursion is associated with higher distortion, although this does depend on the driver. The way to reduce driver movement for the same sound level is to increase the total driver area, which can either be done by having multiple smaller drivers or a single larger driver. For context, a single 15" driver has ballpark the same radiating area as
five 6.5" drivers. Notably large drivers are also specifically designed for the lowest frequencies.
The higher the desired sound levels and the greater the desired bass extension the stronger the argument for larger drivers becomes, but conversely subs with smaller drivers are of course a totally viable option for those with more modest expectations. Both absolutely work for people
