Highly renowned CD and SACD transport, capable of reading the DSD layer on SACDs. Incredible sound, particularly when connected to a similarly high quality DAC via the I2S (HDMI) connection.
Stereophile Class A+ Recommended Component, and Hi-Fi+ Product of the Year Award-winner.
Very good cosmetic condition and perfect working order. Few light scuffs on the black glass top plate (visible from certain angles only) otherwise spotless.
Double-boxed in original packing complete with remote control, SD card, UK mains cable and user manual (digital PDF file).
Specs:
https://www.stereophile.com/content/ps-audio-directstream-memory-player-universal-transport
https://hifiplus.com/articles/ps-audio-directstream-memory-player/
https://www.tonepublications.com/review/ps-audio’s-directstream-memory-player-and-dac/
https://www.hifi-advice.com/blog/re...ectstream-dac-and-directstream-memory-player/
https://parttimeaudiophile.com/2017/08/20/ps-audio-directstream-dac-and-memory-player-revisited/
Looking for £2500 or best offer.
Collection preferred from north Wales but can send fully insured via next day delivery for £35 (highlands and islands might cost more).
Specs:
- Type: Solid-state universal disc player/transport with proprietary ‘Digital Lens’
- Disc Types: CD, HDCD, SACD, DVD‑Audio, HRx, Blu-ray audio, and user-created CD-R/RW, DVD±R/RW, DVD±R DL, and BD-R/RE.
- Digital Outputs: One AES/EBU output (via XLR connector). Supports front left/right channels only. Supports PCM outputs from 44.1–192 kHz. Supports DSD via DSD over PCM protocol to 2.8Mhz (PCM 176.4 kHz). Three coaxial S/PDIF outputs (via RCA jacks). Supports front, rear, and centre/sub channels. Supports PCM outpus from 44.1–192 kHz. Supports DSD via DSD over PCM protocol to 2.8Mhz (PCM 176.4 kHz). Three I2S outputs (via HDMI Type A connectors, but not HDMI compatible). Supports front, rear, and centre/sub channels. Supports PCM outputs from 44.1–192 kHZ
- Direct DSD output to 2.8Mhz
- Other Connectivity: One USB input (front panel, for playing content from USB thumb drives), Ethernet (via RJ-45 connector) for album art and metadata look-up
- Support File Formats: AAC, FLAC, OGG, ALAC, M4A, OGM, AVI, M4V, WAV, DFF, MP3, WMA, DSF, MP4
- Dimensions (H×W×D): 10 × 43 × 36 cm
- Weight: 19 kg (31 lbs.)
- Colour: silver
- Rating: 230V (50-60 Hz)
- RRP: £6,000
