Hi
have some questions to ask that has been bugging me since owning a RME Dac so want to make sure its set up correctly
1. CD Player is connected to my amplifier by using XLRs in bank one of my amplifier to Cd player which the CD player only has one set of connections for XLRs then i use Coaxial lead out of the digital out into the RME Coaxial input but not sure what the Coaxial lead does to honest weather its used to take over the CD player internal Dac or run the display of the RME ???? not sure why i need the extra leads for as i thought the XLRs would cover everything but in order to listen to CD playback i use the the balanced 1 sector on the front of my amplifier
2. In order to stream music i use the OPPO 203 so in order to get a signal i then use XLRs in bank 2 of my amplifier to the RME Dac and then a optical lead from my RME to the OPPO in order to get music playback and the display on the RME to work but in order to listen to streamed music i select balanced 2 on the front of my amplifier .
Now in regards of reference level playback on the RME Dac i set the volume to 0000 db and the Reference level to +7 dbu not 13 dbu as setting the reference level to 13 dbu will cause distortion as the Dac start clipping out as this may be down to using XLRs in the chain but no distortion is herd at 7 dbu and read on the RME forum that someone said you have to lower the Ref level to stop the distortion then someone else said that they had to send there's back to RME to fix the problem so not sure on that one .
and the software is up to date on the RME to 4.8 version
