After its most recent update, Roon seems to have come of age. It now includes options to upsampling to DSD which seems to work well for the bitstream DAC's out there. It allows adjustment for speaker delay to go with its new surround capability and now includes the ability to take the readings from REW for room correction. Those that have the ability to compare still reckon the specialist software like Audirvana and HQPlayer may have an edge in SQ terms but it is closer now. Much closer. One thing that is now apparent is that the power the Room team said you needed, a minimum i3, is more relevant for day to day use. However I am pretty sure Celeron based systems with modest local libraries should still be able to use upsampling to higher PCM rates and use the room correction without too much trouble. That said, my i5 NUC runs 25-30% CPU upsampling to DSD 128, the upper limits of what my Black Dragon DAC presently accepts.
On the road map for further 1.3 builds is software decoding of MQA and ROCK which is their lightweight dedicated Roon operating system, Roon Optimised Core Kit both of which I am looking forward to.
