Unfortunately I can't get it to work.
This really is not a mobile app on doing some digging . You can download your Roon library to your phone but for full use your Roon core must be running and on
But your Roon Core must be running at homeIt is, its a Mobile App for your Roon.
It syncs your Roon library, playlists, saved albums etc and allows you to use it when mobile on your phone, ipad etc
What did you think it was?
And you'd probably need an unlimited allowance on your phone plan.But your Roon Core must be running at home
Got it working no problem, but I think a streaming service may be a better bet, for me anyway.
I don’t leave things turned on and running at home . That’s all . So won’t be using it . Finally read your posts and the sarky tone . Not warranted .Yes of course. Its YOUR Roon.
Did you think they had bought some super-mega cloud storage the size of Brazil to store images of the contents of everyones NAS drives?
I get that Andrew but you watch the Roon Arc video and it tells you all it can do but at the end says your core must be running for this to happen. Spotify you can stream out and about , create playlists and download to listen to offline . So Spotify for me does not give me the quality I want at home but on the move it’s still takes some beating .My LMS is on and running all day every day and given the tiny power it uses for me that is not a problem . All TV boxes and the TV are turned off at night though so I get not wanting things on when your not there . Plus I would as most Core,s are PC based they would use quite a bit more power .
To be honest Danny if it is music while shopping or in the gym then I use a music player with 12,000 flac songs on and wireless earbuds. In the car I preload 12 hours of Radio Paradise and Bluetooth that . Never been keen on Roon as LMS does most if not all that it does and is free .I get that Andrew but you watch the Roon Arc video and it tells you all it can do but at the end says your core must be running for this to happen. Spotify you can stream out and about , create playlists and download to listen to offline . So Spotify for me does not give me the quality I want at home but on the move it’s still takes some beating .
Roon does offer lots of advantages over LMS, one being its multi component support and ability to group - this is a pretty big feature.To be honest Danny if it is music while shopping or in the gym then I use a music player with 12,000 flac songs on and wireless earbuds. In the car I preload 12 hours of Radio Paradise and Bluetooth that . Never been keen on Roon as LMS does most if not all that it does and is free .
To be honest I do not know what that means so I obviously do not need it . I do not have any streaming services so other than RP and other radio stations which are available in LMS along with song lyrics and artist details there is not much I feel should be there .Roon does offer lots of advantages over LMS, one being its multi component support and ability to group - this is a pretty big feature.
