Anyone ever had their speakers painted been contemplating getting mine done as Missus doesn't like the colour and they have a slight dint on them which kills me every time I see it
That will affect the sound more than painting..Mate had this problem with his speakers he had his vinyl wrapped
I doubt the affect is hardly measurable .. if you compare speakers with a proper piano gloss finish the paint layers are probably thicker than a vinyl wrap. Similarly if you do a decent paint job it will be a layer of primer and four coats of top gloss (to allow for T cutting after to remove the inevitable dust specs (for those without a spray booth).That will affect the sound more than painting..
Kindest regards Julian
He has Linn SpeakersThat will affect the sound more than painting..
Vinyl has a totally different flexibility to a Rock hard paint..I doubt the affect is hardly measurable .. if you compare speakers with a proper piano gloss finish the paint layers are probably thicker than a vinyl wrap. Similarly if you do a decent paint job it will be a layer of primer and four coats of top gloss (to allow for T cutting after to remove the inevitable dust specs (for those without a spray booth).
If you have to paint by hand use a roller and paint pads and go for a satin gloss finish .. worked a treat on my pine bedroom furniture
Paint these days though is not rock hard - it is acrylic or polyester .. it flexes and moves(try gently pushing your car bonnet).Vinyl has a totally different flexibility to a Rock hard paint..
We don't wrap speakers in blankets..however thin..iff it wasnt in the original concept of the dynamics of the enclosure.
Excuse my ignorance but what is a 'mil' here? My first thought was mm but I'm sure it's thinner than 3.5 mm .Vinyl wrap comes in thicknesses from 3.5mils to 5.5 mils...
1 mil is around 1000th of an inch. 10mils is around 0.25 of a millimetre. B|Excuse my ignorance but what is a 'mil' here? My first thought was mm but I'm sure it's thinner than 3.5 mm .
It's in the name ..the addition of a vinyl polymer to any material gives it flexibility...that's why we make records and pipes with it ..Excuse my ignorance but what is a 'mil' here? My first thought was mm but I'm sure it's thinner than 3.5 mm .
Paint attaches to the substrate or to intermediate coats at the molecular level..wraps use glue.I think it is thousandths of an inch but I just dug the figures that came out on thickness of car paint and vinyl wraps lol .. I never thought too much about the actual measurement other than to show that vinyl wraps were not significantly greater than a paint job and to also point out the paint uses is very flexible
