Unfortunately clear acrylic is difficult to keep looking good & apart from the usual dust it goes cloudy & soon looks quite nasty.
A dust cover on the deck doesn't help much.
Never used IPA wipes or any other alcohol on my SRM - only Pledge or acrylic polish which does the same job.
Alcohol never did much good..
Good tip, Uz. I didn’t know about ammonia being an issue, but I’m pretty sure we dont have ammonia based window cleaners in the UK. I think they’re usually vinegar
