Hi . Sorry I am not sure.What's the difference between mk1 and mk2
From the web site, and as I am feeling helpful:What's the difference between mk1 and mk2
Thanks for all help with the answer to the original question. It has 2 pairs of inputs and 1 pair of outputs.From the web site, and as I am feeling helpful:
New Look, More Inputs and Outputs
Our second generation preamp now has 3 inputs, 2 configurable outputs and a laser engraved walnut + aluminium enclosure. The chassis is longer, more substantial and remains stable with heavy cables.
Selectable Fixed Attenuation
A new feature is the selectable attenuation, which allows you to reduce the signal by a fixed -10 dB or -20 dB. If your system has too much gain and you can't turn the volume dial past 12 o'clock without hearing damage, this setting will help.
There's a question over whether the dip switches in the Mk2 detract from the clean signal path of the Mk1 so many prefer the Mk1 (myself included).From the web site, and as I am feeling helpful:
No attenuation affects both, OP2 has an additional tape loop option.Think the base switches only affect OP 2
I find starnge that one volume pot can control 2 outputs. All irrelevant with this verion anyway.No attenuation affects both, OP2 has an additional tape loop option.
Thanks for all help with the answer to the original question. It has 3 pairs of inputs and 1 pair of outputs.
Yes, if you simply connect the output of the Mk1 Tisbury to a line input of a preamp (or integrated amp) and turn up the volume control to full (i.e. no attenuation) You effectively get 2 extra inputs.Could this be used as a simple switching box to give more inputs?
i guess you would lose one from the tisbury being connected doh!!!Wouldnt you get 3 inputs?
