I was thinking of wall mounting my Michelle Gyro deck turntable.
Had a look on line and most are too small, or too expensive. I also have a arcylic dust cover for it too so need to allow for this.
So was thinking of making one, I've made road trailers before so a little shelf is no problem to weld up. Was going to make it out of 30mm box section steel.
Can easily build a floating shelf design the size i want, also I want a smaller shelf underneath for the power supply.
I wanted a chunky design so was going to make it a basic square jutting out of the wall and then have upward firing spikes and then build another square box section the same size resting on the spikes (the spikes will be used to adjust the top shelf.) so in the end it will be 60mm thick plus the gap where the spikes are.
What would the best thing to cover the top shelf with? This is where the actual turntable will sit? MDF? Perspex ? Granite?
thanks
thanks
